Old 11-14-2009, 07:56 AM   #15 (permalink)
suspectnumber961
EcoModding Alien Observer
suspectnumber961's Avatar
highcountryexplorer - '86 720 KC 4x4 ST with fiberglass cap
90 day: 20.51 mpg (US)
Elroy - '03 Focus ZX3 w/Zetec DOHC engine
90 day: 33.43 mpg (US)
Magnetic treatment increases efficiency...
http://dl.gmseenet.org:8080/bitstream/handle/123456789/745/Env07%20-%20Govindasa\
my%20-%20Reduction%20of.pdf?sequence=1
http://docs.google.com/gview?a=v&q=cache:l4k12ladcIQJ:www.ekom.si/documents/Labo\
ratoryforPolymerChemistryandTechnology.pdf+Magneti c+treatment+of+fuel+Ljubljana&\
hl=en&gl=us&sig=AFQjCNFy_YkDcKVKa6aLOhq4x19hPmqlQg
In the working principles of their publication Govindasamy et al.1 describe the
physical priciple of magnetic
treatment of fuel. Magnetic fuel treatment works on the principle of magnetic
field interaction with
hydrocarbon molecules of fuel and oxygen molecules Liquid fuel is a mixture of
organic chemical
compounds consisted predominantly of carbon and hydrogen atoms - hydrocarbons.
Due to various physical
attraction forces, they form densely packed structures called pseudo compounds
which can further organize
into clusters or associations. These structures are relatively stable and during
air/fuel mixing process,
oxygen atoms can not penetrate into their interior. The access of appropriate
quantities of oxygen to the
interior of these molecular groups (associations) is thus hindered. This results
in the incomplete combustion
of fuel in the interior of such associations and causes the formation of carbon
particles and carbon monoxide
as well as increased quantities of hydrocarbons emitted into the environment.
In the scientific literature1 it is stated that hydrocarbon molecules treated
with a high magnetic field tend to
de-cluster forming smaller associates with higher specific surface for the
reaction with oxygen leading to
improved combustion. In accordance with van der Waals' discovery of a weak
clustering force, there is a
strong binding of hydrocarbons with oxygen in such magnetized fuel, which
ensures optimal burning of the
mixture in the engine chamber. The consequence of treating fuel with a high
magnetic field is improved
combustion of fuel and consequently increased engine power as well as reduced
fuel consumption. An
additional consequence of improved fuel combustion is reduced emissions of
carbon particles, carbon
monoxide and hydrocarbons.
Results reported by Govindasamy et al.1 show that treatment of two stroke engine
fuel with a magnetic field
of 9000 gauss increases the indicated mean effective pressure and break mean
effective pressure of the
engine threfore increasing also the mechanical power and break thermal
efficiency (BTE). Authors1
2
conclude that magnetic energizing (magnetic field - 9000 gauss) increase the
peak pressure by 13.5%
improve break thermal efficiency by 3.2% and also reduce the exhaust emmissions
of: CO by 13.3% and
HC (hydrocarbons) by 22.1%.
Tretyakov et al.2 studied the effectiveness of magnetic field treatment on
electrical properties such as:
permittivity (), dielectric loss angle (tg ) and ohmic
resistance in relation with magnetic field strength and
temperature on air fuel T-7. Results showed that magnetic field strength (H) of
320 kA/m increased the
maximal tg  from 4 for nontreated fuel at app. 80 C to the value
of 11 at app. 100 C. Magnetic treatment
(magnetic field stzrengths H = 320 and 480 kA/m) also reduced the ohmic
resistance of the fuel while no
effect was observed on the permittivity of fuel. These changes in dielectric
properties of fuel are an
indication of the effects of magnetic treatment on the physical and chemical
properties of hydrocarbons.
Kronenberg3 showed experimental evidence about the effect of magnetic field
water treatment on the
properties of water and the solutes such as CaCO3. Magnetic field causes the
formation of microcrystals
which form a stale suspension and do not precipitate out of the water. It also
reduces the surface tension and
viscosity of water by up to 2%.
CONCLUSION
There is experimental evidence about the influence of magnetic field on
physicochemical properties of
water and hydrocarbons (automotive and air fuel) as well as direct experimental
evidence about the
improvment of the combustion reaction and about the increase of the engine power
as well as about the
reduction of exhaust emissions. On the basis of reported experimental results we
conclude that improved
fuel combustion, increased engine power and reduced fuel consumption as well as
pollutants as a consequence of magnetic fuel treatment are feasible.
Report prepared by:
Dr. Alojz Anžlovar
