Hi,
Just a thought have you considered a TUnit or something similar ? - I think they match an eco4 engine (CR Diesel ?).
They are normally associated with more power but at "min" setting they may give you an economy edge. You may also find a higher power setting results in more economy with different driving techniques especially in the UK with our absence of long, straight highways.
2011 Toyota Aygo Go!
Disclaimer - Postings from this author may be total rubbish. All figures in Imperial MPG unless specified. Use at own risk. Shake before opening. Store in cool, dry place.
Originally Posted by Gabriel Voisin about FWD
The system has the following merits: 1) It makes it easier to lower the centre of gravity and bring it forward. 2) It will free us from that unbelievable stupidity:a transmission shaft and tunnel between the engine in front of the driver and the driven wheels. 3) Front wheel drive will increase the interior space of the body, reduce the car's weight and diminish the cost price 4)It will annoy 320Touring by just being better  .
How to post images in Ecomodder.
