Old 11-19-2009, 01:35 AM   #21 (permalink)
shovel
Originally Posted by bondvagabond View Post
A spool is about a hundred bucks and a lock right is about 220, I never drive around town, I ride my pedal powered infinity mpg mobile, that's why I got rid of the xfi, was making me fat :-) this mud is so hard to get through that I think I will end up doing a spool in the back and a lock right in the front. At least one poster here thinks that the spool shouldn't cost any mpg on strait highway,.
As far as I can tell, you've already talked yourself into whatever it is you're going to do and there's not much point in discussion.
I don't think a spool will cost you MPG's, but I do think a spool on rainy highways - particularly in a vehicle with a very short wheelbase - is a good way to cost yourself a whole lot more.
Spooled (and lincoln locked) 4x4's here in AZ are great on the rocks, and manageable on the road because it's dry 99% of the time so a little scrub on highway corners gives you some "fight" on the steering wheel and reminds you that you're spooled up. In the rain.. not so much. A short wheelbase vehicle differentiates more left to right when turning, and for the same reason will scrub more on turns if locked. Can you get away with it? Sure, the same way you an probably get away with putting 5000 more miles on a bald set of tires. It's just pants-on-head retarded.
2002 WJ Overland E85/gas flex
2002 Motobecane 700DS
1978 ChevroLegs
