Old 11-19-2009, 04:00 AM   #52 (permalink)
orange4boy
marcusmodder
orange4boy's Avatar
The Golden Egg - '93 Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Prius
90 day: 57 mpg (US)
Transaxle Is home. But not before generating a story.
Picked it up from my friend's studio and it seems as advertised. The oil is bright red and clean and thick. There isn't a spot of a leak anywhere. The cables are quite clean with just a bit of dust on them. All the bolts have the original paint marks on them and have never been removed. There is some dirt on the top and it's a bit corroded, but it presumably has been sitting on a shelf at the wreckers for a few years. The input shaft spins smoothly. The only damage I could find was a cracked plastic connector and a few scratches on the inner surface of the output shaft bearing. Not a critical area.
I have to get it into the shop now to clean it up, drain the rest of the oil, clean the pan, fill it with new oil, replace the shaft seals? (they seem almost new), and inspect it as best I can.
Overall pic with a blot of the oil:
output shaft bearing inner surface scratches:
Another shot of the oil and the good condition of the shaft seal:
Oh yeah, Story...
Driving home we had to go through the new Pitt River bridge construction site. (nice looking bridge) The transaxle weighs about 300 lbs and with the three deep cycles at 60 lbs each in the back of the van, she was riding a bit low.
We drove down a temporary ramp with a bit too much speed and although we didn't notice at the time but something went awry. The van started to bounce a lot over bumps. After that there was a strange intermittent knocking / scraping sound over bumps that got worse and worse until I thought some thing really bad had happened.. Of course, as is often the case, a breakdown always occurs when the weather is crappy. Pouring rain gone horizontal in the wind, in this case. Nice.
We stopped so I could see what was up down under. Threw my moving blanket down and in the pouring rain, crawled under to have a look. The right rear lower shock mount bolt must have got sheared off on the ramp because the shock was dragging on the road. I borrowed a wire from the battery pack and tried to tie it up as best I could. The wire was too short to tie it up to the body, so I tied it to the mount.
It lasted about 3 miles before it broke free again. Luckily, We were close to my friend's studio again so we stopped by to effect a more durable repair in his underground parking garage. Thank goodness for that. After a cup of tea and a much more "enjoyable" repair we were on our way again through the wind, power outages and driving rain.
Unloading will have to wait.
