Old 11-20-2009, 03:55 AM   #14 (permalink)
Oval_Overload
24.27 lbs per gallon Co2
Oval_Overload's Avatar
SCarlett - '00 SC1
90 day: 35.22 mpg (US)
The starter is on the transmission. We have no transmission
But no matter... I've got a lead on a separately excited 15kw motor which solves both my problems!
To start the engine, run current through the motor. To vary the voltage output, change the field coil voltage with a potentiometer.
No belts are needed, because both the engine and motor like to run in the 2k range, I'll have my machinist friend make a direct coupler.
Just what I need... More projects :-P
~Jimbo
114 lb/ft of economical fury
Hehehe... If one of your facial lacerations leaves a small scar, you'll have a SCarlett.
