Old 11-20-2009, 04:46 PM   #16 (permalink)
Oval_Overload
24.27 lbs per gallon Co2
Oval_Overload's Avatar
SCarlett - '00 SC1
90 day: 35.22 mpg (US)
I think that using the John Deere generator would be problematic because of the voltage output. If its a 12v or 24v system, you would generate less than 1kw or 2kw respectively.
At least 10kw is needed to get a passenger car down the road at 55 mph. Additionally, changing DC voltage is practically impossible at these high amperages.
The local JY just quoted me $300 for an L24 engine, and $450 for the entire car
I figure we'll need the block, wire harness, ECU, gauge cluster, and fuel delivery system. It will probably be a while before this project gets rolling... I've got a dead Zap Xebra I have to get working and out of the garage.
~Jimbo
114 lb/ft of economical fury
Hehehe... If one of your facial lacerations leaves a small scar, you'll have a SCarlett.
