Old 11-20-2009, 10:51 PM   #11 (permalink)
pgfpro
pgfpro's Avatar
Thanks for both your posts.
I'm trying to get this done this weekend (I only get one weekend off every month)so all the advice is very much appreciated.
I just measured the bottom angle up and it came out to be 28 degrees.
If I make the top around 15 degrees the bottom will be close to 15 degrees also. Is this a better way to go then then 11 degrees top with 28 degrees bottom?
