Old 11-21-2009, 12:13 AM   #27 (permalink)
roflwaffle
101% win
roflwaffle's Avatar
Camryaro - '92 Camry LE V6
90 day: 31.12 mpg (US)
Toy - '82 Pickup
90 day: 24.44 mpg (US)
Originally Posted by some_other_dave View Post
@cfg83--it would be nice if that were the case. But there isn't enough $$ in it, and the regulatory hurdles would be immense. For instance, if my 914 were a 1976 model year one (and therefore subject to smog testing here in CA), I could swap out the old weird funky analog electronic fuel injection for a modern digital system which reduced emissions by 80%, and it would be labeled "GROSS POLLUTER" and I would have to put it back to its original more-polluting form to pass emissions testing.
-soD
Not if you did it right. Go get a newer model year package (engine along w/ emissions systems, the state ref won't care about gearing although its "technically" illegal), install it as per factory spec, make an appointment w/ your local ref, and if everything's installed right and working, they'll give you a nice new MY designation for your much cleaner car after it passes a modestly priced smog check and inspection.
