Thread: Name That Sound
Old 11-21-2009, 12:27 AM   #1 (permalink)
RH77
Hybrid Student Driver
RH77's Avatar
Teggy - '98 Integra LS
90 day: 33.02 mpg (US)
IMA - '010 Insight EX
90 day: 45.43 mpg (US)
Tessie - '06 TSX Base
90 day: 28.83 mpg (US)
Name That Sound
Here's a fun and not necessarily urgent puzzle...
Teggy's pushing 150K miles with over 11 years of operation so it's understandable that things tend to wear...
When the weather first turned cold this Fall, there was a continuous whine/growl after startup until normal operating temps -- then it went away. It seemed to be coming from the driver's side of the engine compartment.
So, necessity mandated re-installation of power steering after an injury (it's no big deal, but I need PS for a while).
Now, despite the temps -- 35F to 65F ambient, there's a whine between 2200 and 2700 RPM. It's transmission independent (happens in Neutral and while stopped and/or in Park).
The sound can be best described as a distant jet engine at low speeds, similar to when a plane is taxiing (low turbine speed, but still that whine).
It sounds like a classic worn transmission sound. Any RPM outside of the range -- there's no sound. It's louder when the engine compartment is cold.
First Guess: Water Pump. Last replaced with the timing belt, accessory belts, and idler pulley at 80K miles. It's getting close to scheduled replacement, but not quite a concern.
Any other guess is with the pulleys, belts, and pumps.
It could be nothing, but it's interesting to diagnose. I suppose EcoModders get to know their cars a bit too well
RH77
Supporting those devastated by the Joplin Tornado
EF5 / 22-May-2011
_
_
