Old 11-24-2009, 11:01 PM   #180 (permalink)
Formula413
Renaissance Man
Formula413's Avatar
Sleepwalker - '97 Firebird Formula
90 day: 20.04 mpg (US)
Spock - '92 VN750 Vulcan
90 day: 49.39 mpg (US)
03MX - '03 Civic Hybrid
90 day: 49.04 mpg (US)
Originally Posted by Christ View Post
Rick -
My only concern is that the TC clutch is actually slipping while at idle, which might be wearing it.
For the sake of the clutch, I'd probably install a throttle switch so that the power was cut if the accelerator isn't being used, or if the brakes are applied, either way.
+1 I would allow the TC to resume normal operation at a stop or very low speeds, the TCC is clearly not designed to handle so much slipping. Under normal conditions it would see much less slippage then even a traditional clutch in a manual transmission since it would only lock when input and output speeds were very close to unity, and unlock under heavy loads.
More choices...
The Following User Says Thank You to Formula413 For This Useful Post:
RH77 (11-25-2009)
