Old 11-26-2009, 01:47 AM   #13 (permalink)
max_frontal_area
Coastrider and Ryland:
"what are you using the truck for?"
most often: freeway with light hauling therefore the desire to improve aero.
occasionally: hauling tires, dirt in the truck. towing; pumper pull 1k Lbs, and
5-6k Lbs. later possibly a 5th wheel camper.
"that auto is going to hurt OverDrive and preferrably a manual is a necessity for FE."
hurt, no kidding a bit too late, it shifts a bit late very hard going into 3rd.
not sure of its efficiency which is a factor about automatics i dislike
a few adjustments out of spec and it will soak up a lot of power.
how does the overdrive actually work on these trannys?
