Old 11-28-2009, 02:37 AM   #12 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
I presume you've tested to a satisfactory extent and found that under your conditions, 30% is the most effective blend?
Have you noticed a change in engine running temps? I found that with diesel, my engines tend to "feel" a little bit hotter, but I haven't actually recorded temps to find out, since ABA testing would require drain/fill cycles, and I don't have time/patience for that.
