I wonder if the idle is set to high, having a simaler affect as if you had your foot on the gas while trying to put it in gear, if that is the case then the fix is free, adjust the idle down, this will also save you gas as the engine will be turning slower at stops, and will have less resistance when the vehicle is not moving.
