Old 11-28-2009, 08:24 PM   #17 (permalink)
88hf
EcoModder!
ratatouli - '01 insight
No scangauge. I'm not sure if I have the obd2 port in the under-dash wiring from the 96 civic, but I'm getting another set of wires, hopefully it will be there.
Cluster was 210 shipped I believe. I'm tracing back all the indicators on it right now. Thought I needed more pins for the connector, still not sure yet. I'm using nude crimp-on butt-splices and shrinkwrap for the connections.
Had a tough day of it today, pulled the cv axles. The old lower ball joints were froze up real bad, had to sawzall them off above the lower arm, remove the upperarm and hammer them out. Have new ball joints and tool on the way. Tomorrow hopefully I'll finally get to pull the old motor.
