Old 11-30-2009, 04:20 PM   #1321 (permalink)
ndavid79
Originally Posted by bennelson View Post
The other trouble that I have is that my analog volt meter only goes to 100 - so even a fully charged 96V system is too much for it. Right now, the volt-meter is disconnected. I may temporarily replace it with with a cheap-o multimeter for now. I would much prefer an analog meter to a digital one though.
Don't forget about the concept of a voltage divider... Two equal value (something high for low watt dissipation) resistors in series across the pack, with your analog volt meter's + connected to the middle... Your volt meter will display 1 for every 2 pack volts (40 for 80v, 60 for 120v, 80 for 160v, etc).
My electrics knowledge is limited in this voltage range, but a quick gander at Ohm's Law & a calculator, gives me two 30kohm'ers for 1/4 watt resistors @ 144v nominal / 170v max.
The Following User Says Thank You to ndavid79 For This Useful Post:
MPaulHolmes (11-30-2009)
