Old 11-30-2009, 11:49 PM   #157 (permalink)
ECONORAM
Yep, gettin' started...
ECONORAM - '07 RAM 1500 QC SLT flex-fuel
90 day: 17.82 mpg (US)
the Avenger - '08 Avenger SXT
Last 3: 27.18 mpg (US)
Send a message via Yahoo to ECONORAM
Originally Posted by aspera View Post
Do you really need a ramp or can you just use a huge splitter? This is one of the biggest around. It's all carbon, but the underside is what's cool. The underside is all foam. They put lots of foam under there and the stuff that hangs too low just gets worn away. The result is exactly the correct ground clearance. No math, no guessing.
That is a good idea. GE does the same thing with the sealing surfaces inside the engine where the fan and compressor blades rub. The material is abraidable (spelling?), so only as much as needs to gets worn away. Presto, perfect seal!
