i think if you do a boat tail, the best way to do it would be to buy a rear hatch off a totaled Prius and modify it so that you don't mess up the only one you have. You could build off the structure that is already there and if you did it right you wouldn't lose the weather integrity. the added weight would probably require larger air-springs to keep the door open but that should be pretty easy to take care of.
