Can you keep it running if you keep the throttle open?
vacuum leak? try spraying a little ether around various hoses, intake manifold, etc. if the engine rev's, you've found the leak
clogged jets? If I couldn't find a leak, I'd rebuild the carb. It's fun, and the kit should only cost $10 or 15.
Roll on,
Stew
