Old 12-02-2009, 11:34 PM   #9 (permalink)
Christ
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
WHOA GUYS!!!
Install yourself a divorce mount xfer case backwards. You'll have some insane ratio, and you'll actually have to get a shorter geared transmission to use it effectively. It gives you two effective ratios, where low is high, and high is low. If you disassemble the Tcase, you can remove the second drive shaft garbage that you won't need, unless you plan on having PTO or something.
I'd like to think that people might open their eyes at some point... instead, I find it more and more likely that I'll just close mine.
-- Author kept secret.
Je ne veux pas d'une meilleure vie. Je veux être heureux avec celle que j'ai maintenant.
(I do not want a better life. I want to be happy with the one I have now.)
