400LBs is about the same amount of engine as the K-series... Maybe the H-series is close. They've both been installed in Civics. The K- has an iron block, so you know that thing is huge and heavy, and HaSport makes a bolt-in installation kit for it (minus wiring, etc.)
Then again, they also have mounts that allow you to put a J-series (V6) into an EG chassis, so noone's saying they're sane.
