Start up conversations with some of the heavy equipment rental companies if you have any local. They rent those solar powered signs you see on roadside construction many times. Occasionally they will have damaged panels that would likely get tossed. Might be able to get some cheap(case of beer) that way. Usually the panels will still have some output unless they are completely trashed. May of may not be useful to you.
JJ
