Old 12-05-2009, 12:53 AM   #3 (permalink)
pgfpro
pgfpro's Avatar
Here's a coolant temperature correction map off my Haltech.
As you can see when the engines coolant is cooler there is more of a increase based in % added to the pulse width of the injectors.
Factory ecu's will even have more of a correction all the way up to normal operating temperatures.
The Following User Says Thank You to pgfpro For This Useful Post:
MetroMPG (12-06-2009)
