Old 03-15-2008, 09:23 PM   #6 (permalink)
friedlbug
JadeAccent - '01 Accent GL
90 day: 35.06 mpg (US)
Sonata - '011 Sonata Hybrid base
90 day: 35.48 mpg (US)
Originally Posted by Ryland View Post
why did you choose a 350 watt motor? Bosch seems to make good motors, so I suspect it will have more real life power then most 350 watt motors, but I still wonder what your top speed will be.
also, any idea on how you are going to connect it to the drive wheel? speed controller?
I got the 350 because it seems that's about the most that can be gotten from 24V using practical amounts of current. I want to stay with 24V because I like the plan in the Autospeed links at the bottom of my first post (manual, switched speed control with regenerative braking). It will be a friction drive.
No pics yet, but I just finished spraying the frame flat black and stripping the old dryrotted tires and tubes off the rims.
Excuse the lack of experience and proper terminology, but anybody know if new innertubes come with the rubber strip that stretches into the rim and covers the spoke connectors?
