In the classic old Honeywell thermostats, you will see a small spiral of resistance wire. It is there to heat up the thermostat itself, instead of waiting for the furnace heat to get there. The contact point for the wire is adjustable, and the more wire you use, the less heat it makes. There may be a similar arrangement in many other thermostats.
