Old 12-06-2009, 01:58 PM   #5 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
Ok, de-energizing the fuel shutoff valve works fine for me (2001 TDI). That's my plan.
I turned off the "ignition", and clipped the lead to the solenoid (don't ground anything out!!) so I could see what happens when I disconnect it cleanly while the car is running.
The engine shuts right down, as expected.
The solenoid is a somewhat hefty circuit though so I will rig up a microswitch on the shifter and control a NC relay with it.
The Following User Says Thank You to dcb For This Useful Post:
Piwoslaw (12-06-2009)
