Old 12-08-2009, 11:56 PM   #9 (permalink)
thatguitarguy
Maroon Ballon - '98 Town & Country LXI
90 day: 26.42 mpg (US)
MaEsTRO - '95 Metro 5spd hatch, 3 cyl
212F is the boiling point of water at sea level, but with a 50/50 coolant mix in a pressurized engine cooling system, the boiling point is much higher, even at high altitude.
The only 3 gauges my 95 Metro has are speedo, fuel, and temp, so I would doubt that any car made since then would have at least a relative temp gauge.
He did say one of his readings was coolant temp, so I think he should be fine to experiment with a block, if he monitors that temp.
