Old 03-17-2008, 12:12 AM   #11 (permalink)
Coyote X
nut
Coyote X's Avatar
Metro XFi - '93 Metro XFi Convertible
90 day: 62.17 mpg (US)
DR650SE - '07 DR650SE
90 day: 55.26 mpg (US)
Moonbeam - '94 Astro Conversion
90 day: 22.31 mpg (US)
Send a message via ICQ to Coyote X Send a message via AIM to Coyote X Send a message via MSN to Coyote X Send a message via Yahoo to Coyote X Send a message via Skype™ to Coyote X
Since a very basic atmel chip would be enough for this I would say the controller would be less than 3 bucks. A 2x16lcd is under $20. So I would say the whole setup with the vss and injector circuits should be less than $50.
A basic interface to calibrate the speed and fuel might need 2 buttons. With a 2x16 display you could have 4 numbers displayed. So I would say instant MPG, last minute avg MPG, Trip MPG 1 and Trip MPG 2. The buttons could be used to reset the trip numbers in normal use. Maybe use a jumper on the board to put it into programming mode. Be a very simple addition but could make it a lot easier for normal use.
There would be no point in putting a tank mpg on there since one of the trip meters could be used for that or not depending on what the person using it wants to do.
My Convertible Metro XFI Plug in Hybrid Project build log
