If you know a Cop it is super easy, just get them to run the VIN.
If you don't CarFax MAY help you. . . . .
You can also try and play the DMV for an ID . . . . .
Or If you know someone in the towing business, have it declared abandoned, a letter will be sent to the owner of the property, a note will be tagged on the car, and you should be able to pick it up cheap. ( That's how it works in Louisiana anyways)
6 speed ALH TDI
