The "brass rod" looks like a part of the differential, BTW. (Specifically, one of the shafts that the "spider gears" ride on.) It is steel; the color is from being coated with brownish gear oil. It should be too far in to affect the axle itself.
Glad to hear you got the problem sorted out!
-soD
