Old 03-18-2008, 02:28 PM   #21 (permalink)
Cowspots
Eco-Nerd
My first aerodynamic improvements!
Hi Y'all!
I finally got my password reset. Now on with this update - Economy Mods:
1) Purchased 175/65R14 rims & tires for my '90 Metro 2dr/3cyl that had 12".
2) Took inventory of my transmissions & will swap F/D ratio to 3.79.
3) Purchased 14" moon disk stainless steel hubcaps.
Plans:
1) Reduce weight of car w/thin aluminum sheet panels to replace door panels.
2) Lightly rebuild 3-cyl. engine and install XFi spec (reground?) camshaft.
3) Add lightweight aluminum sheeting to improve aerodynamics under the car.
4) Switch to lighter weight oils: Engine 5W20 Syn. & Trans lower weight syn.
I'll keep you posted!
Cowspots
