...it's all about "loading" on the engine.
...switching to a lower gear allows the engine to rev higher which reduces its "load" and is shown by the higher vacuum reading, because the vacuum gauge closely parallels the engines "loading".
...best example, is the older non-smog engines, where coasting down a hill in high gear would almost "peg-out" the vacuum gauge...an almost perfect example of "no load."
...conversely, "flooring" the gas pedal would likewise "zero" the vacuum gauge...an almost perfect example of "maximum load."
...the answer to your question is to "mentally optimize" the two by aiming (throttling/shifting?) for highest vacuum reading at lowest RPM that you're comfortable with driving (the people behind you might not agree, but what the heck)...and that sometimes means driving UNDER the posted speed limit.
• 2011 Chevrolet Cruze LTZ 1.4LT 6A
• 2009 Pontiac Vibe 1.8L/SFI 4A
• 2004 Pontiac Vibe 1.8L/MFI 4A
• 2003 Ford Focus ZX5 2.0L/Zetec 4A
• 1971 Dodge Charger 318 3A
• 1970½ Plymouth AAR 'Cuda 340/6BBL 4M
• 1968 Dodge Charger 383 3A
• 1967 Plymouth Barracuda Formula S 383 4M
• 1965 Plymouth Barracuda Formula S 273 4M
