Christ, he used the same type of plug I use on Zap Xebras. Its a recessed male socket in a weatherproof housing with a rubber gasket around the wires. Ours are made by Helga Electric or something like that.
Make sure the contacts stay dry! After 3 years of use, the plug on a customer's delivery truck corroded and the rust dribbled across the contacts. The car still worked, but plugging it in unbalanced the electrical system in half our building.
~Jimbo
114 lb/ft of economical fury
Hehehe... If one of your facial lacerations leaves a small scar, you'll have a SCarlett.
