Old 12-06-2007, 01:23 PM   #1 (permalink)
SVOboy
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 CRX DX
90 day: 66.52 mpg (US)
[Article] Better Fuel Economy with Ethanol?
Here's the first bit of the article, read more here:
Research findings released today indicate that mid-range ethanol blends—fuel mixtures with more ethanol than 10% (E10) but less than 85% (E85)—can in some cases provide better fuel economy than regular unleaded gasoline, even in standard, non-flex-fuel vehicles. The new study, co-sponsored by the US Department of Energy and the American Coalition for Ethanol (ACE), also found that mid-range ethanol blends reduce harmful tailpipe emissions.
Previous assumptions held that ethanol’s lower energy content directly correlates with lower fuel economy for drivers. Those assumptions were found to be incorrect. Instead, the new research suggests that there is an optimal blend level of ethanol and gasoline—most likely E20 or E30—at which cars will get better mileage than predicted based strictly on the fuel’s per-gallon Btu content. The optimal blend varies with the vehicle, according to the findings.
The University of North Dakota Energy & Environmental Research Center (EERC) and the Minnesota Center for Automotive Research (MnCAR) conducted the research using four 2007 model vehicles: a Toyota Camry, a Ford Fusion and two Chevrolet Impalas, one flex-fuel and one non-flex-fuel.
Certainly not a large sample size (only using 4 cars), but it is interesting. Another thing to be wary of is the fact that it is sponsored by an ethanol business association.
However, it is interesting to read and I think lazarus has done some of his own testing that shows something similar.
Want to chime in?
