Oh yes, I've checked out the Peltzer e-bike. That's the gold standard of homebuilt e-bikes, in my opinion. He mad his own jackshaft on his own metal lathe and had a much higher budget for batteries than I do, though. I don't think there's any way you could practically use inexpensive batteries to run a 1HP motor like that with any kind of range.
Just a quick update: This has been so slow going because I have very little free time during weekdays, robbing myself of sleep if I want to do anything after a normal day. I did find time to get to Home Depot yesterday, though, and added springs to the frame on each side of the rear wheel (there were these cool little metal loops in just the right spot). I plan to use spring tension rather than the compression method used in the article. They are highly polished extension-type springs with a listed load limit over 30 lbs each. Also, they look pretty cool. I also picked up a 4' length of nickel covered steel angle (the kind with holes all through it) with which I'll make the 'T'-shaped motor mount. I forgot the PVC elbow for the cooling duct, but am not sure how I'm going to mount that yet anyway.
