A gasoline engine was vacuum in the manifold, that's just the way it works. This vacuum can later be used for brakes, etc. In a diesel there is no vacuum, so the brake assist has to be generated by an external pump powered by the engine. A diesel would work just fine without the vacuum pump, in fact it would have that much less load on its accessory belt or camshaft.
If your diesel has a turbo, then you can monitor the intake air pressure. It's not much, but always something.
Piwoslaw's Peugeot 307sw modding thread
