Old 12-30-2009, 10:20 PM   #3 (permalink)
Domman56
Tank - '76 El Camino Classic
90 day: 25.89 mpg (US)
Sabrina - '91 190 E
90 day: 37.07 mpg (US)
Angel - '88 420SEL
Last 3: 23.01 mpg (US)
Originally Posted by Christ View Post
Because the level sensor changes the fuel level in the tank slowly while you're on the hill, and then the level drops when you're on the level again. Or, the other way around, depending on which direction the fuel level meter is installed.
The situation can be remedied by re-installing the fuel pump so that the lever is located to the side of the tank, rather than the front or rear, but the pump won't always fit in this way.
thanks but why does it only do this in Nuetral?
Tank:
(No actual EPA numbers for car just used F/E numbers when i first got it)
