Old 12-31-2009, 12:23 AM   #15 (permalink)
bestclimb
Northern most ecomodder
reddxhatch - '95 Civic DX
90 day: 46.04 mpg (US)
Originally Posted by rmay635703 View Post
On an older naturally aspirated diesel your throttle position determines fuel flow rate (newer it depends on throttle position and RPM)
Ryan
Not quite, mechanical diesels throttle position will set the volume of fuel delivered when the pump injects it. The frequency that the injector pump does it's thing is tied to RPM. RPM x Throttle position x some number will give you flow rate.
Learn from the mistakes of others, that way when you mess up you can do so in new and interesting ways.
One mile of road will take you one mile, one mile of runway can take you around the world.
