Power steering - replaced with manual steering gear
power steering is totally overrated and unnecessary. In my 2 ton truck, the only time I can even tell the difference is parallel parking or in a 3-point turn. In normal driving the only function of power steering is to waste fuel.
brake booster vacuum pump - replaced with electric vacuum pump
mechanical clutch fan - replaced with electric fan (w/ adjustable thermstat)
alternator - replaced with deep cycle (RV/marine) batteries and an on-board 120v electronic charger (making the truck sort of a plug-in-hybrid-light)
augmented with a small solar panel and with all running lights replaced with LEDs (all 6 stock running lights put together can actually draw more power than the headlights)
Originally Posted by Piwoslaw
A few months ago I returned home just as my neighbor pulled into his driveway. It was cold (around freezing) with some rain and sleet, and he yells to me: You rode your bike? In this weather?!?
So the other day we both returned home at the same time again, only now the weather is warm, sunny, with no wind. And I yell to him: You took the car? In this weather?!?
