Old 01-03-2010, 10:30 AM   #23 (permalink)
Xringer
Old Retired R&D Dude
Little Red - '012 Prius c 2 Two
90 day: 26.38 mpg (US)
Transporter - '09 Escape XLS
My experience with PVC pipe is, it's just about impossible to break the larger diameter pipe.
I have some furniture made over 30 years ago, using 1.5" pipe and it still looks like it did on day-one.
I just built a small Snow Shed using 1.25" pipe and I figured it's going to last about 30 years.
It does flex, and move around in the wind, but a 2x2 wood frame would do the same.
A heavy wood (4x4) or steel frame would stop it from moving, if that was necessary.
As to suitability of PVC in building a frame-work for an aero-body, I think it would depend on the design.
The larger OD pipe has much less flex, and using rigid outer skin with plenty of fasteners could make it very stiff.
Notice the cross-beam I used in the little roof? That keeps it flat, from sagging under a heavy snow load.
If a structure is build using closely spaced support under a rigid outer skin, the skin will add a lot of stiffness to the structure.
That green PVC siding (skin) on my house still looks good after about 30 years.
It's strength today is the same as those spare pieces stored away, just the color has gotten lighter.
It's still tough stuff to cut. Need to use sharp tools to work with it.
The best thing about using the PVC Pipe, is the price. The second best
thing, is the ease of use. Since I have a cut-off saw, I can put together
a PVC pipe structure together very quickly..
It's also great for plumbing in experimental projects..
If the electrical power fails when the basement is getting flooded?
Just flip a valve and use the city water pressure to pump it out..
Liberty Pumps : Back Up Sump Pumps
PVC is great stuff to work with..
Cheers,
Rich
