Interesting toppic.
Does the heat transfer through the motor's metal casing / housing?
If so, then maybe I can add heat sinks to my motor to make it tolerate heat better.
(same concept as a computer CPU heat sink)
That is a problem I'm concerned about when i do my build because in Arizona the summer heat can reach 120F / 49C and Zero humidity.
