Originally Posted by alexander.foti
As the scangauge doesnt have high accuracy on fuel tank size measuremeant I have told it that its 10 gallons as per the manual which says round up.
...uh, which
SGII instructions are you reading and following (Ver 4.5, 5.0 or 5.1)?
...early versions mentioned comparing "percent" value, while the newest (ver 5.1) "Quick Setup" mentions comparing "gallons" fuel used.
...I'm sure the "gallons" method described in the "Quick Setup" pamphlet is the most accurate method.
