I wish I had room under the ZJ for an overdrive unit. I hate to thinkof the driveline vibes I'd get with a shortened and steeper rear driveline...
You don't have overdrive??? I know mine has it cause there's an O/D off switch on the dash to the right of the steering column. and I also know that they come with it.
It says in the manual that the fourth gear is overdrive. But I have counted many, many times, and its definitely got 4 gears and fifth being overdrive. I count the shifts, and it shifts into o/d (5th) at 46, leaving it at about 1300 rpm.
