Old 01-12-2010, 09:01 PM   #10 (permalink)
KITT222
Ecomodder en route
KITT222's Avatar
Vib - '04 Vibe base
Originally Posted by RobertSmalls View Post
The Volt should be less expensive than the Leaf because the Volt is a Plug-in Hybrid Electric Vehicle, with ~40mi EV range. The Leaf needs $10k-22k of lithium batteries to achieve its 100mi EV range.
The Volt is not a plug-in hybrid. It is an extended range electric vehicle. The only reason there is a gasoline motor is so when the batteries drop to 30% charge, the gas motor kicks in, and recharges the batteries. Its an EV1 with with four doors, and an in-car recharging station.
