Old 03-21-2008, 06:54 PM   #27 (permalink)
extragoode
Oden - '00 Frontier Crew Cab
Pickups
90 day: 21.99 mpg (US)
Malinda(WJ) - '03 Grand Cherokee Limited
90 day: 15.28 mpg (US)
Nerdcycle - '81 CM400E
Motorcycle
90 day: 53.8 mpg (US)
Bumblebee - '08 V3
Motorcycle
90 day: 69.17 mpg (US)
Originally Posted by DifferentPointofView View Post
Hmmm. What RPM range do you run at 70? If you run near 2K, then you're probably doing fine. around or over 3k? we gotta work on that.
I got out on the interstate for a couple minutes yesterday, doing 70 in a 65 I was running just a touch over 3Krpm. (3050-3100). Also, I've done some research on my transmission and I'm pretty sure the only replacement that would be better would be the 6-speed nissan introduced in 2004. It looks like it would be a bolt on replacement, but I have two problems. I'm guessing this would be extremely expensive in comparison to the others. Also, it only gives me an advantage of 5% new 6th gear over old 5th gear. That doesn't really seem like it's worth it to me. The worst thing I found out is that the standard diff for this truck in the 4x4 configuration is 4.38:1! I haven't even looked for replacement diffs, because I don't think there's any way I could rationalize it to my wife even if I could manage to convince myself. Obviously, I've never done this before, but doesn't it make sense that since I'm trying to get smaller ratios, the overall size of the gears would be smaller? So couldn't I get the gears from some taller diffs, pop covers off the diffs, and replace the gears in place without changing the whole axle? I know it seems a little lego land like, but why not? It'd be a lot cheaper, possibly even if I had to have a couple gears custom made, right?
