Old 03-21-2008, 06:16 PM   #28 (permalink)
Duffman
Originally Posted by DifferentPointofView View Post
You don't have overdrive??? I know mine has it cause there's an O/D off switch on the dash to the right of the steering column. and I also know that they come with it.
It says in the manual that the fourth gear is overdrive. But I have counted many, many times, and its definitely got 4 gears and fifth being overdrive. I count the shifts, and it shifts into o/d (5th) at 46, leaving it at about 1300 rpm.
Are you sure that you are not counting the torque converter locking up as a gear. I had a friend whos parents Grand Am had a 3 spd and he swore it was 4 for the same reason.
