Old 01-17-2010, 04:30 PM   #15 (permalink)
Christ
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
Steve - '92 Festiva
Originally Posted by Rainh2o View Post
not sure if this helps or not, but I converted my portable generator to run on propane by using an old carb off another engine. It was actually real easy and direct. Here is the link to the instructions...
Converting a generator to run on propane
This is how alot of people do their conversions, actually. The only issue is when you can't find a carb that works for the engine you're using... usually, 4 cylinder carbs are fairly easy to find, but if you've got a 2 cylinder or single cylinder generator, the carb is too big for it.
I've done a few conversions from forklifts into trucks and cars, though. Many fork lifts have truck engines in them.
