Old 01-17-2010, 11:36 PM   #2884 (permalink)
adamj12b
EVVette - '71 Corvette Coupe
Originally Posted by edown View Post
The mosfets are only rated at 75 amps, 280 volts
If you are using 280V fets, you must be wanting to use a system with higher voltage then 144v??
-Adam
www.EVVette.com - 1971 Corvette Coupe Conversion to all Electric!
www.AdamBrunette.com - Machining, CNC, Robotics and Electronics.
