Old 03-22-2008, 08:43 AM   #22 (permalink)
LostCause
Liberti
LostCause's Avatar
Thunderbird - '96 Thunderbird
90 day: 27.75 mpg (US)
Take what you want, leave what you don't...
Driving Habits:
Drive 55mph max
Drive Without Brakes
High Load Acceleration
Engine Off Cruise
Pulse and Glide
Reduce Alternator Demand (LED lights, drive during day, etc.)
Easy Mods:
Max+ Tire PSI
Low Viscosity Engine Oil
Low Viscosity MTF
Remove anything sticking in the wind (antenna, side mirrors, spoilers, etc.)
Wash/Wax Car to Perfect Smoothness
Grill Block
Rear Wheel Skirts
Repack Wheel Bearings w/ Synthetic/Lightweight Grease
Tire Alignment (0 Camber, 0 Toe)
Underbody Panel
Kammback
Seam Tape all Gaps
Tougher Mods
A/C Delete
P/S Delete
Alternator Delete w/ Engine Kill Switch, Starter, Deep Cycle Battery
Electric Water Pump
Lower Car + Stiffer Springs
Lightweight Wheels + Skinny Large Diameter LRR Tires
Transmission/Gear Swap
Reground Camshaft + 13:1 CR "Atkinson Cycle"
Turbo-Compound
Radiator Plenum
Reshaped, Fiberglass Honeycomb Body Panels
Front-Wheel Skirts
Side Skirts
Front Wheel Splitter
Rear Wheel Boat Tail
Lean Burn
Sealed Engine Bay
Composite Intake Manifold
Molybdenum Disulfide Piston Coating
Dual Probe Sparkplugs
Increased EGR
If you are concerned about how your car looks/what other people think you aren't going to get very far...
- LostCause
