Old 12-06-2007, 11:51 PM   #12 (permalink)
MetroMPG
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 125.37 mpg (US)
U.F.O. - '00 Insight
90 day: 85.75 mpg (US)
Driving efficiently when nobody's looking? C'mon! :P
Cold air is good for power. The idea behind a warm air intake is to intentionally DEpower the engine, which requires a wider throttle opening to do the same amount of work. A wider throttle opening means reduced pumping losses. One of several reasons diesel engines are more efficient is because they have no throttle plate.
A grille block is just that: closing up some of the front of the vehicle ahead of the radiator. A significant amount of the total aero drag of a vehicle is airflow through the radiator. If you don't NEED the airflow, closing off that opening will help. Don't melt your engine though.
