Old 01-21-2010, 03:06 PM   #13 (permalink)
alexander.foti
Originally Posted by PaleMelanesian View Post
The tank size has no bearing at all on the mpg readings. It only affects the "Miles to Empty" and "Gallons to Empty" readouts. I pretty much ignore it.
Engine size and fillup offset are what you should worry about.
Sorry for not responding for soo long, I have been very busy.
I appreciate all the responses.
My question is that if you say fillup offset affects the accuracy then the tank size does also technically as when im filling up I input the offset im inputting it against 10 gallon tank size rather than 10.6 gallons....
